Andy in Germany
- Rottenburg am Neckar
For some time I've been developing a mildly crackpot idea about improving lighting for taking pictures of models (that is, trains and silly tabletop games, not the other sort, sorry for the disappointment) I'm looking for a solution that allows me to take passable pictures with my phone without heavy shadow all along one side of a model or the other.
Now, any remotely "professional" lighting is obviously going to cost silly money, and it is far and above what I need. All I'm after is a couple of light diffuser boxes with sufficiently bright lights in them that I can use occasionally. I've found a couple of videos which show how to make these out of cardboard and tin foil, which is well within my abilities, but my ability vanishes as soon as I start to look at the lights themselves.
Apparently, LED brightness is measured in Lumens now, and this is more important than Wattage. Is this the case?
The tutorials I've seen talk about using "60 watt light bulbs" but locally companies seem to be a bit inconsistent about whether a light's output is measured in Lumens or Watts. Given that I'll be using a diffuser, of course, I need a higher output as well.
So, how can I work out a ballpark figure for how powerful the light needs to be? I have a notion of using rechargeable LED building floodlights, because it means I can move them around a game without worrying about cables, but I have no idea if they will have a sufficient output. Some are advertised as having "2000 Lumens" which would be useful if I knew what that meant: is that a bright light, a dim light? Or somewhere in between?
Also, as the specifications seem to change a lot, is there a way of calculating Lumens from Wattage on LED's?
