Can someone help me to justify to spend over £100 for a pair of waterproof overt trousers?
knonist
These link
Purpose for daily 10miles (20miles return) commute on country lane., don’t really want to buy it but kind of need it.
Anyone can suggest something comparable to this?
Anyone think we are going to have a dry winter this year?
I have recently bought a new waterproof shell for £300….. although I must say it is a very versatile jacket and carries a life time warranty. ( I have had a few waterproofs that leaks after 4-5 years and each cost around £150 ) , so i'm trying not to spend anymore on bikes, at least for a while...
[url="http://www.arcteryx.com/Product.aspx?EN/Mens/Jackets/Alpha-LT-Jacket"]Link[/url]
4F
Suffolk.
I can't sorry. They look like boil in the bag material and you will probably end up boiling / sweating more than you would gain from any waterproof materials
I use Ron Hill bikesters on my daily 15 mile (30 mile return) and have done for the past 5 years. On a yearly basis I will probably get only wet 20 or 30 times max and given that the commute only takes an hour that is bareable
dellzeqq
pre-talced and mighty
SW2
Ron Hill Bikesters
her nibs has just bought the top of the range Gore jacket at about £160, but that's a different thing. Legs don't usually get as cold - although a pair of overshoes really can make a difference
4F
Suffolk.
Ron Hill Bikesters
Agreed, add in a set of full length mudguards and the jobs a good un.
K
knonist
Ron Hill Bikesters
I got wet almost everyday since Aug...
But you are right, leg dont get as cold.... unless it is p***ing down
Amanda P
Bikesters and a Buffalo Teclite for me. No boil-in-the-bag effect, and you dry out very quickly. The Buffalo isn't cheap at around £100, but there's no waterproofing to wear out or rub off - just bung it in the wash each weekend.
I don't believe any conventional waterproof is breathable enough to keep you dry when cycling. If it's really waterproof, you'll get sweaty. If it isn't, you'll get wet.
Buffalo (and, I think, Paramo) stuff works differently. The shell gets wet and, in heavy rain, saturated, but a lot of the rain just wicks down to the hems and cuffs and drips off. In heavy rain, some soaks through, but the fleecy layer keeps your skin dry as long as you're working hard enough to be generating a bit of heat - and as long as you're wearing it next to your skin.
Unfortunately, when you stop working for any length of time (like, say, waiting for a ferry), you can get cold because the wet jacket is still drawing your body heat to evapourate the water, like a wick. The solution is to take of the Buffalo and put on something you've kept dry. Unfortunately, that means that when it's time to get back on the bike, you have little choice but to put the damp Buffalo back on. Not fun. (Another solution is to put something on over the top of the wet Buffalo. You stay wet, but at least you don't freeze. And you can resume drying out when you get back on the bike).
But as a practical solution to cycling in wet weather, Buffalo stuff really works. I'd recommend it.
Jezston
London
These: [url]http://www.wiggle.co...ers/5360044563/[/url]http://www.wiggle.co.uk/p/cycle/7/Gore_Bike_Wear_Ultra_IV_GORE-TEX_Cycling_Trousers/5360044563/http://www.wiggle.co.uk/p/cycle/7/Gore_Bike_Wear_Ultra_IV_GORE-TEX_Cycling_Trousers/5360044563/
That link doesn't work for me, just tries to go to the abbreviated address!
What trousers are there?
I have a £110 pair of Gore UltraPants, and they are not boil in the bag at all. Very nice indeed they are.
http://www.arcteryx....Alpha-LT-Jacket
the wiggle link does not work for me - but I am guessing the gore trousers - I ordered a similar pair (if it is the gore trousers) and would have kept them if they were the right size - they looked good and felt good other than size. My cycling top does not get me wet or boil in the bag which is great , but I make very good use of the arm vents to help. I have no problem getting wet on the way home from work, but I hate putting on cold wet skin tight cycling gear for the return trip if I got wet in the mornings. I am still on the look out for come decent cycling trousers - the black and light mountainerring set I have are totally unsuitable for cycling in unfortuantly, but excellent for what they are designed for. I have the arcteryx soft shell top and trousers and love them - they are extactly my size which is unusual, I am just waiting for my old waterproof to give up the ghost to get something like the arcteryx waterproof top you linked to - I do a lot of winter mountaineering so no issue with the cost becuase it lasts and it is fanastic and it is often cheaper in the long run to get the better quality and not have to think about it again for 10 -15 years etc.
3tyretrackterry
East Midlands UK
Ron Hills and a £20 pound waterproof from Sports direct I admit i only cycle 5 mile each way but even when it has really hoofed it down ive never got really cold. I find that knowing i can have a shower at both ends of my commute really helps i may be of a different mindset if i couldnt shower when i got to work
£100 on a pr of trousers i could think of several other bits for my bike i would rather spend my money on
CopperBrompton
Bicycle: a means of transport between cake-stops
London
eVent trousers here. £99, totally waterproof, amazingly breathable (so much so that in changeable weather I quite often leave them on, which I never did with Goretex).
K
knonist
Yes, it is the gore ultra
and this is the exact reason why i bought the arcteryx alpha lt!
