Total beginner here.
Please help me pick between Carrera Crossfire 3 Hybrid Bike and Specialized 2014 Crosstrail mainly for commuting to work and some cobble road rides on the old town.
The Specialized 2014 Crosstrail Sport Disc Hybrid looks nicer, and appears to be higher spec. But is it worth the £100 extra?
Many thanks in advance
Specs are as follows:
CARRERA Approximate Weight (KG): 13.8kg Brake Type: Mechanical Disc Brakes Forks: Suntour NVX-HLO 700c Suspension fork damped with lockout Frame Material: Alloy Gender: Mens Number of Gears: 24 Suspension: Front Suspension Wheel Size: 700c Cassette: 11-32T Chainset: SRAM E450 3.0 Front Brake: Tektro Lyra mechanical disc brake Front Hub: Alloy with QR Front Mech: Shimano FD-M310 Gear Shifters: SRAM X4 trigger shifters Geometry: Comfort/Leisure Headset: Semi integrated Pedals: Wellgo Alloy pedals Quick Release Front Wheel: Yes Quick Release Rear Wheel: Yes Rear Brake: Tektro Lyra mechanical disc brake Rear Hub: Alloy with QR Rear Mech: SRAM X4 Rims: Double wall alloy rims Saddle: Carrera Seatpost: Carrera 350mm x 27.2mm black alloy Stem: Alloy Type: Hybrid Bikes Tyres: CST multi surface tyres
SPECIALIZED FRAME - Specialized A1 Premium Aluminium, w/ mudguard/rack braze-ons, forged dropouts, kickstand mount FORK - SR Suntour NEXi Coil, aluminium lower, custom integrated fork crown, mechanical lockout, 60mm travel HEADSET - 1-1/8" FSA Ahead, semi-integrated, 8mm cone spacer STEM - Alloy, 4-bolt, 10-degree rise, 25.4mm clamp HANDLEBARS - Specialized riser bar, alloy, 8-degree backsweep, 25mm rise, 25.4mm GRIPS - Specialized Body Geometry XCT, dual compound, lock-on FRONT BRAKE - Tektro Draco, hydraulic disc, dual piston, 160mm rotor REAR BRAKE - Tektro Draco, hydraulic disc, dual piston, 160mm rotor BRAKE LEVERS - Tektro Draco, hydraulic lever FRONT DERAILLEUR - Shimano Acera REAR DERAILLEUR - Shimano Acera, 9-speed SHIFT LEVERS - Shimano SL-M390, Rapidfire CASSETTE - Shimano, 9-speed, 11-32 CHAIN - KMC X9 CRANKSET - SR Suntour XCR, 9-speed, square spindle, w/ chainguard CHAINRINGS - 48/36/26, w/ chainguard BOTTOM BRACKET - Cartridge bearings, square spindle, capless bolts PEDALS - Composite plastic body, loose ball, w/ reflectors RIMS - Alloy double-wall, 32h FRONT HUB - Disc, double-sealed, dual-lock nuts w/ 19mm contact side, steel axle w/ Semi RLCA steel QR REAR HUB - Disc, double-sealed, loose ball, dual-lock nuts w/ 19mm contact side, QR FRONT TYRE - Specialized Trigger Sport, 60TPI, wire bead, 700x38c REAR TYRE - Specialized Trigger Sport, 60TPI, wire bead, 700x38c INNER TUBES - Standard Schrader valve SADDLE - Body Geometry Targa Sport, steel rails, 155mm SEATPOST - Alloy, 2-bolt, 12.5mm offset, 27.2mm SEAT BINDER - Alloy, 31.8mm
