Castelli Endurance X2 Bib Shorts
mark st1
Plastic Manc
Leafy Berkshire
5A2ACCDA-DFB5-46B6-9DFA-89A1BD873C04.jpeg F7523418-7CD9-4FDB-A23A-CE00F478CDAC.jpeg FC2A2C68-B704-4F54-B268-F247E8726201.jpeg A short designed for long rides in the saddle & features Castelli's famous Progetto X2 Air seatpad delivering superior rider comfort as the miles roll by. The newly engineered bib strap construction is also great on a wide range of body shapes.
Maximum technology for supreme comfort; The Progetto X2 utilises ventilating perforations to keep you cooler and dryer on endurance road rides. The design allows air and moisture to flow directly to the surface fabric for quick evaporation. The shape of the pad has received minor updates based on pro feedback. The Progetto X2 Air Seatpad is constructed in 3 layer components, each dedicated to a specific purpose to create the most comfortable seat pad on the planet.
1. Skin care layer: A four-way stretch, microdenier, seamless, bacteriostatic layer made to adapt to the shape of your body and saddle without any folds in the fabric.
2. Seamless integrated technology cushioning layer: Multi-density foam with infinitely variable thickness. The thickness of the pad is engineered to place the padding where you need it most for maximum comfort.
3. Viscous comfort inserts: Perforated viscous padding is added under the highly sensitive ischial and perineum pressure areas.
Size 3XL
From a smoke pet free home extremely comfortable just a size to big unfortunately. Only worn twice paid £105 from Wiggle
£65 posted
mark st1
mark st1
Plastic Manc
Leafy Berkshire
Sold
