This is a set of 2 Cateye halogen lights, one 10W and the other 15W. They are powered by 2 x 6V NiMH rechargeable battery packs.
Everything is present and correct - 2 lights, handlebar clips, cabling with built-in switches, batteries, and battery holder which attaches under your water bottle holder, BUT:
* I blew up the charger, so there is no means to charge the batteries *
Also, a piece of the battery holder has broken off but the battery is retained by a strap so this doesn't affect use.
This is a good set of commuting lights for someone with the wherewithall to build a charger or spec one from another source. I will include the cable from the charger so you can splice it into whatever you use.
Because of this major flaw, I'm only looking for £10 plus postage - the equivalent of these lights go for well north of £50. Grab yourself a bargain!
![DSC_0173.JPG DSC_0173.JPG](https://www.cyclechat.net/data/attachments/252/252112-0388be6db14bdeaba1f2efd687505227.jpg)
