1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
cateye rear carrier bracket
Discussion in 'Commuting' started by johnM, 10 Jun 2008.
  1. johnM
    johnM New Member
    Hello everyone, I'm new to the board and I was hoping a bit of help advice could be provided.
    I have recently bought a Cateye TL-AU 100 rear light, however it only comes with a seat post bracket and I was hoping to mount it on the back of a rear pannier rack.
    It appears that this bracket does the trick:
    https://secure.cyclexpress.co.uk/products/Rear_LED_Light_Bracket.aspx
    Does anyone know if this will do the trick?
    Thanks
    johnM
  2. domd1979
    domd1979 New Member
    Staffordshire
    Yep, certainly will - if your pannier has got the screw holes on the back then should be fine. I've got a Cateye TD1100 mounted on my rack using one of those.
  3. mootaineer
    mootaineer New Member
    London
    I use that too.
    IIRC it comes with plastic zip ties as well as a screws.
  4. Plax
    Plax Veteran
    Wales
  5. Mister Paul
    Mister Paul Legendary Member
    It'll work with the LD270, as the bracket is in the back rather than underneath.
    Not sure about the LD260.
  6. OP
    johnM
    johnM New Member
    Thanks for the advice everyone, looks like a yes then.
    I think your right about it probably not working with the LD260 as it appears to have a horizontal bracket underneath, where as the TL-AU 100 has a vertical bracket on the back.
  7. neslon
    neslon Well-Known Member
    The Toon
    I used mecchano on mine!
  8. domtyler
    domtyler Über Member
    Surely blu tack would have been sufficient? :wacko:
