KnackeredBike
I do my own stunts
In my bicycle repair man toolkit I kept a pump that came free with some tools. It clearly wasn't the most amazing but I figured good enough to get me to limp to somewhere with a track pump.
In about 40,000km of riding on Conti Gatorskins I have only had two punctures, one close enough to walk to a LBS and one yesterday about 200m from work.
Went to repair the puncture at lunchtime. Repair kit worked great but the bloody pump wouldn't get the tyre even moderately inflated. Then in frustration I ended up snapping the plastic Presta adapter at the end of it.
Luckily an LBS is only 20mins walk from work and I now have a Pro Performance which I have tested and goes get to decent pressures.
tl;dr Test your emergency repair kit before you need to use it in the middle of nowhere!
(I considered CO2 inflater but I much prefer to repair rather than replace the tube as I find it quicker and less likely to leave something sharp in the tyre (3mm shard of flint yesterday). I think that would be harder to do with CO2.)
