Easytigers
Hi there,
Had my new bike for a couple of weeks but finding that every time I'm in the big ring at the front the chain is catching the derailleur - no matter what gear it's in at the back. I know that you are to expect some grinding if the chain is crossed etc but this is in every gear when using the big ring.
Only way to stop it is to hold in the lever for shifting (when it shifts up it seems that the cage comes over far enough but then when you release the lever it slides over a couple of mm and this makes the difference.
Sorry am rubbish at maintenance so some of the terms for the different parts might not be spot on. Any ideas?
Oh...if info is needed...the gearing system is Shimano 2300 with a Sora front mech.
Thanks
Thanks
