Hi All,
I want to ask you how do you clean your chain properly. What is the most effective way?
I can see some people use these chain cleaning devices that are filled with some degreaser I presume.
Is it better to clean it with degreaser/water risking the corrosion or better wipe with kerosene/white spirit/petrol/diesel?
As it comes to brushes I reckon you can only use plastic not steel wire to cause abrasion. I was just wondering if steel wire can be used as this will last longer than these plastic ones that go bad pretty quickly and then it goes to the landfill.
Am I also good in thinking that it is better to have a silver rather than black cassette sprocket to spot the filth accumulating?
Thanks
Thanks
