Chain cleaning
Dogtrousers
Lefty tighty. Get it righty.
There and then. If you leave the chain damp from cleaning, without lubing iut, then you will get surface rust.
Unless you cleaned it with white spirit. ;)
But yeah, why would you not lube it there and then? You have dirty hands and rags and stuff, so finish off the job while you're on a roll.
J
JackStraw
is this a philosophical difference between white spirit and WD40 for cleaning the chain?
presta
I used to clean my chain every 1500 miles or so, and put a drop of oil on if it looked a bit dry after rain, and with that regime I seemed to get component lives as good or better than those who go to great lengths over chain cleaning.
keep a microfibre cloth on hand and run the chain through it at the end of each ride to clear the gunk off
The dirt that the cloth wipes off the outside is not what's doing the damage, what's wearing the chain is the dirt trapped in the capillaries where the cloth won't reach.
My view is that the main effect of cleaning chains is that it makes people feel better.
J
JackStraw
That's why without the ultrasonic weapon this cannot be removed. I cleaned the chain thoroughly and I still see (under a magnifying glass) some grime in those tight spaces.
si_c
Wirral
I agree completely, but my rationale is that by cleaning the chain after each ride you're removing any surface dirt/grime and that will prevent it from working its way into the rollers over time, hence it's preventative. Properly lubricating the chain and cleaning it after is similarly important - any lubricant working it's way into the rollers will likely displace some grit/grime and wiping the chain properly afterwards helps remove this.
Both these also help remove surface residue on the chain which doesn't help the chain work and just attracts dirt - I try to keep all my chains dry to the touch.
  • Like
Reactions: C R
Dogtrousers
I clean my drivetrain (gears, cassette and chain) when I do my general regular bike clean. It may be a futile activity but it looks clean afterwards. And this is also when I do my general checks that everything else is safe and working OK.
C R
Worcester
I don’t clean my chain
Me neither, I do occasionally clean my bikes chains, though.
steverob
Buckinghamshire
That's what I've done previously but wanted to be sure it was the right thing to do. Had a thought/fear that maybe if I was to put lube on but then not use the bike for ages that would possibly negate the effect or something - better to know rather than to assume.
geocycle
I just use the mickle method on my derailleur bikes. Wipe the chain with a bit of old towel after each ride on surface and sides a few times. Every few rides squirt with degreaser and then wipe with towel. Cassette and jockey wheels also get done but tbh the cassette is always fiddly without taking it apart. The rohloff bike chain gets very little cleaning at all.
midlandsgrimpeur
Hi All,
I want to ask you how do you clean your chain properly. What is the most effective way?
I can see some people use these chain cleaning devices that are filled with some degreaser I presume.
Is it better to clean it with degreaser/water risking the corrosion or better wipe with kerosene/white spirit/petrol/diesel?
As it comes to brushes I reckon you can only use plastic not steel wire to cause abrasion. I was just wondering if steel wire can be used as this will last longer than these plastic ones that go bad pretty quickly and then it goes to the landfill.
Am I also good in thinking that it is better to have a silver rather than black cassette sprocket to spot the filth accumulating?
Thanks
I clean the bike and drivetrain around every 300km (every 5-6 days for me). Morgan blue cleaner and a chain brush to get all the gunk off, then sponge it with warm soapy water and finally rinse with clean water.
In between cleans I will run the chain through a clean rag and wipe jockey wheels and chain rings to remove surface grime.
If the bike gets wet on a ride I will clean everything and re-lube the chain straight after.
dicko
Derbyshire
After using Scottoiler Blue chain oil for my motorcycles chains over the years does anyone else use this oil for their bicycle chains ?
