In all my years of cyclingI've never failed to solve a problem (without this excellent site of course).This one is baffling though.
I have finished restoring a dawes fleur 5 speed non indexed racer for my Daughter.
Its only done around 1100 miles from new but has been unused for many years. Everything is at it should be (I think).It kept unshipping the chain from the top of the front sprocket in bottom gear.So I have put on a new chain as the original was tight and the wheel was only just in the dropouts.
This is now what I consider the correct length with nice tension and no sagging. It runs nicely throughout the gears smoothly, but its again unshipping the front sprocket as before. Where do I go from here as everything appears lined up correctly ?
Forgot to mention new inner and outer cable fitted if it could be relevant
