Chain help
yenrod
I've one of these:
Now to fit it you've got to cut it tO size then fit it together with 1 of these:
Now does this mean that yo've got to run the chain long so if it snaps you can remove the snapped section of chain, then rejoin :biggrin: :smile: :biggrin:
Hopefully only one link will get broken, and usually it's the outer plates that go, so they can be replaced with another quick link. I guess if the inner plates also go, you'd have to use some of the spare links you saved when shortening the chain initially, and use 2 quick links, either side of the replacement inner links.
