I make it tight enough that there's no noticeable slack viewed side-on but the rear wheel doesn't slow down instantly if you spin it. If you're using a chainset designed for FG/SS I reckon you can get away with less tension but if your front ring is from a double or something it doesn't take much for the chain to come off. It's happened twice on my Pompino with a 105 chainset, and never on the Genesis with a Sugino one.
Cheers, I googled it and opinion varied. It's an off the peg fixie, so (should be) designed for it. Wheel slows down naturally but always stops at the tight spot now, might play it safe and loosen it off a tad.
Something isn't perfectly symmetrical. Chain gets tighter at a certain point. I'm told better parts reduce it but I definitely have a noticeable tight point.
At the tightest point you should be able to 'spring' the chain about half an inch up and down. Any tighter and bearings, sprockets, chainrings and chain will all wear rather more quickly.
