oldgreyandslow
- Farnborough
Can someone please just clarify the method to set the chain length on a 105 set up with a 28 tooth rear please?
I thought you just put the chain on the largest front and rear, without going through the pulleys and that was the length, however for an 11-28 this document http://techdocs.shimano.com/media/t...SI-5X90B-003-00-ENG_v1_m56577569830702204.PDF
seems to suggest doing this and ading 2 links.
Also I guess I need to adjust the B tension screw to get clearance for the pulley at the top end.
Ta
Ta
