I recently fitted a new 9 speed chain to a hybrid. I used the old method of big chainwheel to big cog at the back, plus an inch. Once it was all assembled it was obvious just looking at it that the chain was too short. The derailleur cage was at about 135 degrees in top gear. Today I have added a couple of links and it is much better, and is shifting through the gears more smoothly. Problem is I now have 3 snap links in the chain. I did boob today, I should have joined the end of the additional links to the old snap link then I would have only had two. My reasoning was to spread out the joins a bit so as not to have them all together. Anyway, what is the perceived wisdom. Can I run a chain with three joining links or should I cut my losses and get another chain. Possibly the fact I am asking the question may be a clue to the answer. Thanks in advance.
