Chain maintenance on long tours ?
YMFB
At home I use a park tool hand held chain cleaner with a detergent, brush the cassette and chain ring, let it soak and rinse with water, before drying and re-lubing. This system works well for me.
The last few days we rode the Hadrians wall C2C, got wet everyday and didn’t do a great job of bike cleaning/maintenance.
What do people do on longer tours away from home, such as an unsupported LEJOG ?
Thanks in advance for any constructive suggestions
VinSumRox
Scottish Borders
I take a wee bottle of chain lube and a j cloth or 2 and just run then chain through the cloth a couple of times and then put a bit of lube on the chain.
If not really mucky I just put a few drops of lube on the chain.
You can get a bit carried away with chains. A squirt of GT85 from time to time and rarely a drenching and a drag through with a cloth as above. Whoever invented the chain wear tool created a lot of potential misery for the worriers out there.
roubaixtuesday
self serving virtue signaller
We did a very long (5 months, 5000 miles) tour last year.
To my surprise, a single chain and cassette lasted the whole distance.
Maintenance regime:
- relube and wipe clean after rain
- occasional (~1000 miles) more thorough clean, which was just more lube and more wiping, scraping gunge off jockey wheels etc.
That's it.
I think you may be overthinking this; essentially as long as a chain is lubed it'll be OK.
PaulSB
Waxed chain, small cotton cloth and a very small amount of liquid wax. I'm currently using Silca but have been a big Squirt fan in the past. After a dry or damp day a quick wipe with the cloth, after a very wet day, hours and hours of rain, clean with the cloth and re-wax. I only ever re-wax after a lot of water exposure, usually only after a wet winter ride.
Don't get carried away with chain maintenance on tour. For LEJOG if you started well prepped it shouldn't be necessary.
presta
I service the bike before I set off, and again when I get back, and in between that I oil the chain if it looks a bit dry after heavy rain. That's it for tours up to a month and 1400 miles. The oil I use is Finish Line, not because it's anything special, but because the bottles can be trusted not to leak in the pannier.
geocycle
On multi week trips I take something like Finish Line in a 20 ml centrifuge tube. It was very useful once in northern France on some very dry off-road routes where the whole drive chain was red with dust. For short trips I usually don’t bother.
PaulSB
That sounds like the best possible reason for choosing a lube. 👍
