OK, I recently replaced the whole drive train - crankset, cassette, and chain. I readjusted the gears, and most of the time it's all fine - smooth and almost silent.
I know that if I use small-small or big-big I will get chain rub, but I am getting some rub when I'm in the middle ring. I would think that you ought to be able to use any gear on the cassette when in the middle ring without it rubbing. It's rubbing in the lowest 3 gears, so I suspect I need to tweak the front mech.
Can someone advise on the best method to adjust the mech to minimise this problem?
Thanks.
Thanks.
