robjh
- Cambridgeshire - almost Essex
I have a 10 speed rear cassette, 11-28T, and triple chainring 50-39-30T. I recently noticed that when I was in the middle chainring but largest rear sprocket, the chain would slip off the middle and onto the small (inner) chainring, even if this caused it to rub and bend around the front derailleur which was still in a middle position.
So I replaced the chain (the old one was pretty worn), and also the middle chainring at the same time as this too was showing some wear - see picture of old and new chainrings further down.
But with new chain + chainring I STILL get slippage when in middle front and large rear. I have traced it to one particular tooth on the chainring, directly opposite the crank. I believe I have followed Shimano's instructions and installed the chainring in the right position on the crank.
As both chain and chainring have been replaced, there must be something else at play here. I still have the old cassette for the time being, and the front derailleur, and everything is in much the same position on the bike as before. The chain line in this combination is at quite an angle, but presumably was the same for the many months that it didn't slip.
The chains : old KMC X10-93 ; new KMC X10-L
middle chainring : old Shimano Sora 39T, new Shimano 105 39T (FC-5703)
cassette : Shimano 105 10sp RC-5700
Does anyone have any ideas?
