Chain stretch
jimbut
Have one of the Park tools chain checkers. Want to replace chains before too stretched. At what reading should I be replacing the chain ?
youngoldbloke
.75
J
jimbut
Ta very much for that YoungOldBloke. I am just about on that ( or will be in a few weeks ). My KMC SL chain has lasted extremely well and I`ll be changing for the same again. Think I`ve about 5,000 K on it ( accidentally reset my comp a few months back ) which is pretty remarkable for such a light bit of kit... got about half that on my original Ultegra chain ! Anyway ta again for the supplied info.
Crankarm
Nr Cambridge
Have you checked the chain for stretch all the way around it's length rather than in just one position? Surprisingly stretch does vary along the length of the chain. I have found some sections have stretched more than others. I change a chain when between 0.75 and 1.0 and have not observed any ill affects to the cassette, chain rings or jockey wheels.
HJ
Cycling in Scotland
Auld Reekie
At £53 I would hope it lasted longer that a £20 chain...
Deleted member 1258
[/quo
On my fixed the chain is full of tight and loose spots but its a cheap one from the local market and its been on for about ten months now.
tyred
Ireland
That's more likely to be down to a chainwheel which isn't quite round or not mounted concentrically.
Deleted member 1258
I recon its a bit of both myself, I got the chain ring as centred as I could when I fitted it and have checked it a couple of times since.
J
jimbut
Reply to HJ above re £53 for KMC SL chain. It actually cost £31 from Merlin Cycles. That was price last year from Merlin ( May09 ). This year cost is £38. Still a heck of a lot cheaper that the cost at a lot of online suppliers. I consider it a price worth paying even tho Merlin have raised its charge AND removed the option to buy several at decreasing unit cost.
To the poster who referred to checking several places along the chain. I did not think to do this but having taken your advice I find no variation along the chain length.
HJ
Cycling in Scotland
Auld Reekie
My point was that at that price you would expect more for your money, that is about the same price as a Dura-Ace chain. If I were paying that much for a chain I would not be happy if it only lasted a couple of thousand miles, but if I were buying a Shimano HG53 then I would be surprised if it lasted more than 3k miles...
