chains
GilesM
East Lothian
If it hasn't got a split link, you'll need one of these:
http://www.chainreactioncycles.com/Models.aspx?ModelID=7843
Although if it's a bike with derailleur gears it won't be called a split link it will be a power link (for an SRAM chain) and it will look like this:
http://www.chainreactioncycles.com/Models.aspx?ModelID=871
I hope this helps.
S
shumidrives
so if i get a chain tool i will be able to fit a new chain without a split link/power link???
how do i do this??
Oldlegs
Frogs are people too.
Norwich
You will need a chain tool to cut a new chain to size - they come with a few extra links so they will fit any geometry.
Shimano chains join with a special non re-usable pin for which you need a chain tool. You get one pin with a new chain.
SRAM and others use a power link (does'nt need a chain tool) and again you get one with a new chain.
There are a few videos on you tube - heres one
View: http://www.youtube.com/watch?v=NVYV4WsYuVM
The tricky part is ensuring that the link moves freely afterwards at the joint.
I would add that I have been sold a couple of absolute pieces of cheese called "chain tools" - get the basic Park tool as in Giles' first link as it is made strong enough for the job and then practice on a spare chain if you have one.
SimonC
Sheffield
Bend the chain at 90 degrees to the way its supposed to bend, frees up stiff links.
