007fair
- Glasgow Brr ..
I wanted to clean the chain rings and so removed them as they are very hard to clean otherwise
I didn't want to tamper with the BB so I just took off the large and middle chain rings (Triple from a Giant SCR2), cleaned all three (the smallest was easily accessible while still attached) and put then back on.
I was careful to finger tighten the screws first then gradually tighten each one by the same amount
Question - I have read somewhere that it is important not to over tighten these screws.
Park Tools recommends 44-88 inch pounds of torque for aluminum bolts, and 70-95 inch pounds for steel bolts.
I did not use a torque tool I didn't over force them but they are tight .. Should I be worried that they are not the correct tightness?
