Changing Forks
J
jowwy
Not here offten enough to argue
maybe about 5mm
J
jowwy
Ok here lies a the problem - the crown to axle length is the same, but as i have got an intergrated headset the overall length is a bit shorter due to no bottom cups between headtube and fork is this a problem??
RecordAceFromNew
Swinging Member
West London
In case there is any misunderstanding A2C for forks is from centre of axle to where the crown race sits so is independent of headset dimension. However if you are changing the headset then the stack height of the bottom cup does affect the geometry, in fact exceptional high (well up to 14mm I think) special bottom cups can be bought for crown/frame clearance issues, but they are very rare.
So if as you said the A2C is the same, and since not many headset bottom cups differ in height by more than a few mm, can you explain what the problem is?
J
jowwy
Ok - measured wrong then. From were crown race sits to axle is 6mm shorter than the old forks.
J
jowwy
old fork
New forks
now you may be able to see my slight problem better in that on the unicrown fork the crown race sits higher than the crwon race on the carbon forks by aprrox 6mm ( not as much as the first pic shows, but was the only pic i could find that illustrates the slight problem
aesthetically it ll looks fine, but is the 6mm difference gonna cause that much of a geometry problem.
J
jowwy
Cheers mate.
J
jowwy
Thanks to RAFN for his help with my fork problem - all fitted now and the bike feels so much lighter already - next will be changing the wheels to planet x model c's - they will take another kilo of weight off the bike - will be a nice cool 10kg's then - will also change back cassette to a 13-26 and fit better crank arms - Thinking ULTEGRA SL across the board.
