Changing pedals often an issue?
Mralexrides
Assuming I correctly remove pedals and put new ones on correctly, does it matter or risk damaging the threads changing pedals often? I will be changing flat to clipless and back to flats. Have you any tips for removing or knowing which pedal is left or right? If its not indicated on the pedal? Thanks
iluvmybike
Not if you do it correctly! On clipless pedals it will be obvious which are R or L. On flats it is usually marked either ono the end of the axle or on the spanner flats
T4tomo
look out for L and R marked on them, remember L is reverse thread, apply a bit of lithium grease to the threads, and don't cross thread them - start them off gently by hand making sure your are square onto the pedal
This is my favourite golden rule - I've no doubt it has saved me many expensive mistakes. You CANNOT put them on wrong this way!
Having said that ... I think repeated assemble/disassembly has drawbacks, so I'd disrecommend it. But if the poster is happy with those drawbacks, carry on - I just think (s)he may be underestimating the hassle.
On the plus side, they should never be seized on when you REALLY need to take them off!
Start the thread off by hand in the reverse direction. When you hear it click you can start rotating by hand in the correct direction.
You need the tighten pedals quite firmly.
You might wear out the thread your soft and expensive aluminium cranks.
Jody
I swap pedals all the time depending on what riding i'm doing. You'll be fine as long as you follow the advice above
Mralexrides
Mralexrides
You can get pedals with SPD (MTB version) one side and flat on the other. Much more convenient than swapping pedals. I use them on bikes used for both tootling round town and longer rides.
https://www.chainreactioncycles.com/shimano-xt-t780-spd-trekking-clipless-mtb-pedals/rp-prod67250
There are cheaper versions.
Thats ideal mate thanks!
boydj
Paisley
Pedals don't need to be all that tight. Finger-tight and just a little more is plenty, especially if you are changing them frequently.
cougie uk
Those shoes say they're for indoor cycling. Never heard of the make. I'd get a known brand from a proper bike shop. Comfort is key.
Found this on amazon pretty light and with the spd cleat:
View: https://www.amazon.co.uk/gp/product/B08SJR69G4/ref=ox_sc_act_title_1?smid=AG2KIIGJS9SEP&psc=1
is it too good to be true? so i can pedal in normal shoes or use spd if I'm inclined. Would they work with these shoes
View: https://www.amazon.co.uk/gp/product/B091GRTM2T/ref=ox_sc_act_title_1?smid=A24X97WGA4NT1J&psc=1
You won’t want to walk on those shoes on a small slippery metal cleat standing proud of the shoe. Get some mtb or touring shoes with a properly recessed cleat if you value your neck!
something like this
View: https://www.amazon.co.uk/Shimano-Unisexs-BMT301L43-Parts-Standard/dp/B07FGLPXVR/ref=sr_1_10?crid=15LMBKZVHRFP3&dchild=1&keywords=shimano+mountain+bike+shoes&qid=1623360622&sprefix=Shimano+mountain%2Caps%2C168&sr=8-10
Mralexrides
Mralexrides
I don't mind a normal cycling clip in shoe if I got the option of the flat pedal. I guess a mountain bike shoe would make sense but I love the look of those shoes in particular
