clanking noise from rear wheel on rotation
alecstilleyedye
nothing in moderation
my boardman cx comp was rather noisy coming home on friday; a clanking noise from the rear. i put it down to some loose spoke reflectors (sounds like them moving up and down the spokes), which i removed.
the clanking noise remains when i lift the back wheel and spin the wheel. it doesn't appear to be a once-a-rotation noise, and i've looked at the disk-brake alignment and there doesn't seem to be anything untoward going on there.
mudguards aren't rubbing, rack is tight and it seems to not be drive-train related.
stumped really; unless the hub is on its way out, in which case i'll put a warrantee claim in against halfords; bike is only about 3 months old :sad:
Threevok
Growing old disgracefully
South Wales
If it's not only happening under load, and you've checked the spokes and all is tensioned fine - then it could very well be a hub bearing, i'm afraid
Does it happen if you take the wheel off and spin it holding the axles by hand ?
Tangoup51
Sounds like either your hub bearings need a service but more likely it could be your cassette body has kicked the bucket. - On the 2014 cx they are pretty cheap generic nasty cassette bodies (one of the ways they cut corner on the price)
*edit mine went after 8 months of completely dry riding.
Levo-Lon
Check the chain link is secure and all the other links too.
If one side of the link has detached it will catch .
alecstilleyedye
alecstilleyedye
rear hub had water got in and washed out grease and rusted the bearings. fixed for gratis by halfords :thumbsup:
Very typical for these, unfortunately. I had exactly the same thing on my MX Comp. I ended up replacing the whole rear wheel, with a Mavic Cross one, after the second failure, the spokes were a nightmare to keep tensioned on the original wheel as well.
swee'pea99
After three months? :eek:
I've been having a bit of a time with the rear wheel on my daughter's bike recently - cones loosening off. But the wheel's probably about 40 years old. To the best of my knowledge, no water has ever got in and washed out grease. How can a brand new wheel on a £600+ bike be that crap?
Tangoup51
Comp/Team bikes from Boardman have insane VFM. Halfords last sold the CX Team 2014 (10 speed, discs, etc) for £500 but I bought mine for £675. - They are expected to cut corners in certain areas, like the front mech & rear freehub body
My hub had the same issues roughly the same time as the OP, I'm not at all mad, for the price I paid, I should of gotten alot less anyway.
