Cleaning/maintenance after messy road ride...
P
Phil4000
Actually that's a good point, I did not think of the salt roads. I ride on a CF bike. Idk what bike OP has but if steel then good to quick-wash after a ride. Maybe need riser inhibitor. That reminds me I have to that on my steel steed.
Boardman SLR 8.9. Carbon frame, rim brakes.
Looking out for a Boardman ADV 8.9, in aluminum frame. Or something close.
but I can't get 3-4 bikes!!!
Pardon. 3-4, is that all.
Yes you can !
VinSumRox
Scottish Borders
It wasn't generally the frame that was affected by the salt corrosion, unless the paint had chipped, it was cables, gears, brakes, almost every bolt on the bike that seemed to suffer! All bike bolts seem to be made of the least corrosion resistant metal available!
This - need to pay attention to nuts and bolts in winter, and SPD pedal parts. WD40/GT85 etc once in a while. SPD's take a bit of a battering with salty roads, so I'd spray them regular. The metal retention plates go rusty if not careful.
P
Phil4000
So gave the bike complete clean with muc off products, done in half an hour. Sprayed down drivetrain with MO 94 after cleaning, lubricated chain.
Never felt the drivetrain move so smoothly, looks like a clean has been needed for a while. Has made a big difference.
Muc off products seem to work well, I got them because they were on sale and claim to be environmentally friendly. Checked with Muc off if I needed their drivetrain cleaner, or if the Nano tech would work ok for cassette. He said Nano tech should be fine, their drivetrain cleaner goes deeper.
Had a Specialized hybrid way back in the 90's, didn't pay much attention to maintenance to the detriment of the bike. So have learned a lesson from that.
Half an hour once or twice per week, well worth it.
Going to invest in a stand!
A winter bike should have generous mudguard/ tyre clearance, mounting eyelets for chromoplastic full length bolt on 'guards, and a reliable, well sealed style of bottom bracket.
Best to wax the frame so mud doesnt stick.
I never wash after winter rides.
P
Phil4000
You won't regret that purchase
https://www.amazon.co.uk/Taylor-Bro...nance/dp/B0D6SN9FSN/522-2143526-0956247?psc=1
Sufficient? Additional precautions with carbon frame?
P
Phil4000
What about drivechain? Road salt in particular...
Webbo2
I wouldn't as the weight of the bike could pendulum and crack the tube. That's my thinking anyway. Probably saw it years ago written on here.
If you go in any bike shop they hold the bike by the seat post. Why would it pendulum if it’s not tight on the post it will rest on the saddle. Having it tight enough on the top tube to work on things like the BB you are likely to crush it.
