How new? If you bought it from an LBS maybe they will look at it.I was riding my new mtb today
I bought it second hand but it was barely riddenHow new? If you bought it from an LBS maybe they will look at it.
Yeah I'm gonna go and check my bike tomorrow morning and tighten things up. But not too much.Apart from the dangling dog tag, the other noise sources that I found were:
The reason that so many things were not tight enough was that I don't have a torque wrench and have damaged things in the past by overtightening bolts. I had obviously been overcautious on this bike because all is now quiet!
- Cleat bolts were not tight enough
- The raised tread on the sole of one of my (mountain bike style) SPD shoes was rubbing against the pedal so I trimmed it back
- The bolts holding the plates on the tops of the pedals were not tight enough
- The headset was not tight enough
- The brake/shifters may not have been fixed to the bars tight enough
- The chainring bolts may not have been tight enough
Oh, and a clicking sound on another bike was caused by my right ankle catching the end of the cable to the front derailleur once per pedal revolution.
I thought you greased the saddle clamp bolt, not the rails. You want the rails to be gripped snug.Check the saddle is on tight - possible lightly grease the rails.
Similarly, I've had the bit on the end of my shoelaces ping the FD.Oh, and a clicking sound on another bike was caused by my right ankle catching the end of the cable to the front derailleur once per pedal revolution.
Blimey, there is a really loud echo in this room!One extra thing to look at is to make sure you are not clipping the cable on your FD when the crank passes. That could explain it only occurring in certain gears.
Blimey, there is a really loud echo in this room!![]()
