Coaster brakes - are they bobbinous?
Pennine-Paul
Goth on a bike............
i like coaster brakes for their simplicity and consistent (albeit average) performance in any weather. one thing to keep in mind that they are have some drag due to the spring rubbing inside the clutch and may start to squeal if it's low on grease (clutch turns with the wheel while the spring sits still). you can see this in the photo with the rusty old grease and how the edge of the spring coil is ground flat. it becomes better when it's run in.
I have to say it did clunk and clank a bit the first hundred miles or so,then it quietened right off,not that you could feel anything dragging,
it occasionally has a bit of a rattle, but if you apply the rear brake briefly, it stops (I'm guessing the brake shoe is causing the noise)
Love the coaster brake on my SS. First time I've ever used one in a cycling career spanning 50+ years!
Dan B
Disengaged member
Coaster brake on the Christiania trike, seems to work well to control speed on downhills on the rare occasion I remember it's there. The front brakes to tend to make the trike weave from side to side when applied at speed, which is quite disconcerting for the rider and probably even more so for the kids in the box
