Hi all,
new to forum so apologies if i've got the format wrong.
I'm trying to look into buying a new bike for commuting and general riding around the area and getting fit. I'm between 5'11 and 6' and mostly using the bike on roads/pavements, with a light bit of uneven pavement but its all paved areas. I'm travelling 5miles some days, and about 2.5 miles on others.
Its a small commute, so I've kind of got into my head Hybrid is probably best, as i'm unlikely to benefit from the speed of a road bike drop bar, but i'm open to suggestions on this as I know there is contrasting opinions on this.
I want to spend somewhere between £500-600 on my bike, and looking at the best components possible for this. I understand for my usage its probably not worth getting a bike with suspension, so i've been looking at rigid front bikes.
So far i've been mainly eyeing up the Triban RC500 flat bar - Sora from decathlon:
https://www.decathlon.co.uk/rc500-flat-bar-disc-road-bike-sora-id_8554412.html
this has a really good set of equipment and flat bar.
however this is basically the same as the RC500 drop bar - there's no difference bar the handle so i'm really wondering whether the drop bar version will be better, or whether the comfort of the flat bar makes the difference.
also if i was going to get a drop bar then the RC520 with the 105 parts looks amazing, but then it's a lot to spend on a road bike for a first bike.
Another hybrid suggestion i've looked at is a Pinnacle Lithium 4, but i'm not sure if its as good as the triban for components wise.
https://www.evanscycles.com/pinnacle-lithium-4-2020-hybrid-bike-EV339939
Whats your opinions based on my usage for the best bike and why, and should i stick to flat bar or should i dabble in drop bar? I'm aiming to go to an independant shop nearby to get some suggestions too but understand they may be more expensive.
