Compact chainsets - are they universal?
swee'pea99
Looking to replace the 39/53 chainset on my new +1. It's Shimano BB. Will any compact chainset fit (so long as it's not Campagnolo, presumably). Thanks.
Any chainset will fit (compact or otherwise) providing it is compatible with a BSA standard 68mm threaded BB shell and its associated BB axle or BB cups.
swee'pea99
swee'pea99
Thanks, but it's got one of those new-fangled BBs - I should've said. What are they called? External? I'm not sure. The best pic I have is
...don't know if that helps.
Sterba
London W3
Why not just change the rings, if you need different gears, then any Shimano rings will fit. It's an easier swop than changing the whole chainset
swee'pea99
swee'pea99
I believe you can't go below a 39 on a 'standard' chainset - to go to 34, you have to get a compact.
Pontefract
Its 38th, the Bolt Centre Diameter is usually 130mm on a normal double/triple, 110mm on a compact doubles and triples, and usually 74mm on the inner ring (though this can vary, as can the outer)
Mr Bunbury
That type of BB is a Shimano design called "Hollowtech II". Any compact chainset that is designed for Hollowtech II will fit.
jdtate101
Ex-Fatman
Yep, all Shimano cranks are 24mm axle so any other 24mm type crank will work just fine. As others have said, standard rings use 130BCD and compacts 110BCD, so you cannot swap rings between the two types. You're probably best off just buying another crankset and selling the 53/39 to offset the costs, or just get stronger and ride with the 53/39. FYI fitting a 28 on the back with a 53/39 gives you the same ratio at the bottom as a 50/34 with a 25 cassette.
J1780
that's what I did a few years ago instead of buying a new chain set I fitted a cassette with 28 sprocket
