Correct BB axle length ?
yenrod
I used to use a Shimano 113mm with a non- shimano c.set BUT i then bought a fancy TA Ti'/Alu axis bb - totally nice it is - feels real smooth !
Thing is, that the spacing now is wider on the drive side and the same on the non-drive.
Do I buy another, the 110mm, or put up with it as it shifts ok and is 'in the middle of the block' when you look at the the chainline...
Anyone help ? - if i do need the 110mm (??????)
4F
Suffolk.
The difference of the spacing between the 113 and 110 will be on the non drive side so would not help.
Y
yenrod
Good point ! :evil:
TheDoctor said:
TBH, Yenners, if it works and you're happy I'd leave it alone.
Life's too short to worry about 3mm :rain:
Juh know what Dr I was thinking about that y.day on my ride - i'll take the Drs orders !
:cheers:
Thanks - y'all !!!!!! :biggrin:
