Thru axle spacers
Billybreadface
Hello, I've bought some Superteam carbon wheels. Look really good. I had to fit a 7mm spacer on the non-drive side. Works find but a bit fiddly. Question is can you get an 'extended' version of the push fit top hat piece on the non-drive side. I need one c31mm.
Your wheel will be off to one side so will need re-dishing. Most manufacturers do replaceable end caps. I assume you've bought the wrong size.
