If its the same as the new one on the left, then I suspect its a standard concrete riven pattern available from B&Q. Personally I'd smash the broken one up to remove it and whatever its been bedded down with. Normally a mortar mix. Get new mortar mix it up and do 4 or 5 big dabs then mount new slab on top. Make sure enough under the new slab for it to compress down so you can level it. It's not mortared joints so should be easy enough. It's possible that the broken slab has been bedded down on sharp sand so thats another way to do it. Eitherway no more than a £15.00 diy fix.
I suspect it’s fairly standard 300x300mm. Measure it to make sure.
You will struggle to get an exact match, but a new one will weather in over time.
Or take the opportunity to replace them all at once with something you like.
