Moodyman
Something creaks when pedals are between the 11 – 12 o’clock position. Happens all the time, but worse when powering from stationery or slow rolling.
· I’ve put new cleats on, cleaned and lubed the pedal externals.
· Checked bottom bracket – no sound when I’m off the bike and rotate pedal by hand.
· I’ve cleaned and greased pretty much everything else (including saddle, spokes where they overlap & nipples).
· No cracks in frame – thankfully.
· Seat post cleaned and greased.
· Headset cleaned and greased
· Handlebar & Stem joint – cleaned and lubed
· Pedals spin fine by hand so internals okay.
· Pedals threads were cleaned and greased about 2 months ago – might repeat to remove this from equation.
· Kickstand cleaned and oiled
· Mudguards joints lubed
· Checked all bolt and they’re lubed and tight.
· Light fittings tight
· Crankarms tight
I’ve exhausted the Jim Langley list and tried everything suggested in previous ‘Creaky’ questions on CC. Is there anything I’ve missed?
· Crankarms tight
