Creating a useable Gravel Bike drivetrain, a guide to SRAM Mullets.
chriswoody
Northern Germany
The Problem with 1x Drivetrains.
SRAM released their Rival 1, 11 speed groupset back in 2015, the first commercially available groupset aimed squarely at gravel bikes. Given the off road capability of these bikes, the groupset mirrored mountain bike groupsets with a single narrow/wide chainring and a clutched derailleur. Unfortunately though, they then chose to make the derailleur a medium cage with a maximum capacity of 42 teeth, giving an overall range of just 420% when used with a 10 - 42 cassette. With the standard 40 tooth chainset this gave a groupset that was far too highly geared and this is a trend that continues today on gravel groupsets, whether it's Shimano or SRAM.
So why is this a problem? Well for gravel racers or folk who ride compacted, almost smooth gravel roads, this is undoubtedly fine, but for those of us that like to seek more adventurous off road trails, or even go bikepacking, these gears are far too high for serious off-road use. So no doubt many are now laughing and thinking what on earth is wrong with a good old double chainset, well let's have a look at that.
Shimano’s GRX groupset is aimed squarely at gravel bikes as well and as we can see below, it has a whopping 502% range, so already much better. Look closer though at the ratios and we can see again, it’s heavily leaning towards the top end, with the lowest gear being only 23 inches, far too high again and this isn’t just Shimano, but an industry wide trend.
Introducing the Mullet.
So what’s the solution? Looking across at mountain bikes and specifically SRAM GX Eagle 10 - 52, we can see it has 520% of range and more importantly a lovely low 18 inch gear when paired to a 34 tooth chainring, perfect for steep ascents loaded up. Yes we are losing some of the top end, but really if you're not racing this isn’t a problem.
This notion of sticking mountain bike gears on a drop bar bike is known as the Mullet drivetrain and it’s not a new concept, my Dawes from the early nineties has a mountain bike groupset and gives a lovely wide range of gears, albeit with a triple chainset.
How to Convert your Derailleur.
So if Mullet drivetrains are so good, why do we not see Mullet drivetrains on stock bikes these days? Well in a nutshell it’s technically not possible. You see, since 10 speed drivetrains, the cable pull ratio has differed between road and mountain. Essentially the amount the derailleur moves for a single click of the gear lever, so Mountain bike derailleurs won't index properly with road shifters. SRAM achieves this differentiation by means of a plastic fin under the derailleur which the cable wraps around. The Mountain one is a different size and shape to the road one as can be seen below.
Now it turns out that on SRAM’s higher tier groupsets, this fin is actually removable by means of a circlip. So it is a simple matter of changing a mountain one for a road one and we now have a SRAM GX Eagle derailleur that will now function perfectly well with a road shifter. Something that SRAM fails to officially acknowledge is possible because they would rather you buy a wireless groupset if you want to create a mullet drivetrain.
There are other ways to create a mullet, with different jockey wheel cages, Jtek shiftmate etc, but with SRAM, changing the cable fin is by far and away the easiest and most reliable.
Upgrading to 12 Speed.
So now I have a mountain bike derailleur working with road shifters, I could leave it alone there and just fit a wider range 11 speed cassette. The problem with that though, is that I run the risk of increasing the gap between the ratios too much and I happen to actually like the 10 - 42 cassette I currently have. What if there was just a way of keeping the 10 - 42 cassette but adding a larger 12th cog for emergencies? I.E. use the 12 speed GX Eagle cassette I talked about earlier? Well it turns out there is. You see SRAM likes to keep it’s engineering quite simple and as a result it’s eminently possible to modify your shifters. There’s a company in the English Lakes called Ratio Technology who engineer and provide upgrade kits for SRAM shifters, amongst which is a 11 to 12 speed conversion kit. Here is the contents of their 12 speed upgrade kit for 11 speed SRAM Double Tap shifters. They also include a cable fin, but I could have just used the one from my old Rival Derailleur.
Modifying the shifter is a simple case of removing it from the bars, keeping the hydraulic hose attached and then remove the side cover. Using the supplied M2.5 bolt we can draw out the axle holding the shift components in and then we can remove it all. Here’s the original shifter stripped apart, with the old 11 speed ratchet and red cable spool in the middle and the new Ratio 12 speed ratchet below.
Swapping the ratchet and cable spool over is the work of moments and then we pop it all back together. The new cable spool isn’t a necessity for this conversion, but the original SRAM one is made from plastic and prone to failure and SRAM refuse to make it available as a spare part, thus writing off your shifters. The Ratio one is made from aluminium and much less prone to failure so now is a good time for an upgrade.
With the cassette I spent a good while with gear ratio calculators trying to work out the best combination and finally I settled on the 10 - 50 12 speed cassette, whilst this only gives me a 500% overall ratio, crucially if I keep my 34 tooth chainring the 10 - 42 range of the cassette stays the same as I currently like and the 50 tooth cog gives me a low gear of 19 inches. Also going with the smaller 50 tooth cog means that the jump up from 42 teeth is not as pronounced as with a 52 tooth large cog. Fitting the cassette is easy, the XD driver on my hub will take either 11 speed or 12 speed cassettes, so no fitment problems there.
So with everything bolted up, I followed the SRAM set up instructions to get the Hi/Low Screws set, then the chain sized followed by the B-Gap and then lastly the final fine tune. It now works lovely on the stand so I just need to get out there and get some kilometres on it. I’m really happy how it all went together and finally I have a decent wide range transmission that will hopefully fulfil my riding style and needs perfectly.
JhnBssll
Suffolk
I've had zero problems with my ratio/SRAM mullet setup so far, it's a great solution to the 1x high ratio gravel conundrum and relatively low cost to boot :smile: nice work dude.
chriswoody
chriswoody
Northern Germany
That's good to hear, I read similar online as well so hopefully mine will give me many good years of service.
I've managed over 200km so far on mine and it feels really good, the shifter is really crisp and feels like new. I've had no shifting issues at all, the indexing works perfectly and I have really fast and precise gear changes. I'm going to be heading down to the Alps later this year for a trip so looking forward to seeing how well it all goes.
I've been running a very rarely seen in the wild shimano double mullet set-up for several years without issue. 46/30 in the front with an 11-42 in the rear.
I remember your thread about this, it's a nice set up you have there with a good spread of gears.
oxoman
Currently running 38 x 10 / 44 12spd wireless sram axs, ideally looking to get a lower ratio for bike packing. Any low cost thoughts. Sram say it's change the bottom bracket etc.
chriswoody
chriswoody
Northern Germany
Which groupset do you have? With AXS you can of course buy a GX Eagle Derailleur and then use an Eagle Cassette like I have, but then that won't be cheap. though you could sell your existing Derailleur to recoup some of the cost.
When you say "Sram say it's change the bottom bracket etc." I presume you have a SRAM crankset and are pondering changing the crankset instead?
I'm running a Race Face Aeffect crankset on my bike and I can use chainrings from 28t through to 38t. So until now my solution was to run 34t on a daily basis and swap to a 28t for bikepacking trips. This is certainly cheap because the rings were only €30 each.
So it's certainly one option, but you would need to buy the Race Face Cranks at around £100, then a 34t and a 28t chainring at around £25 each. Then the Race Face cranks use a 35mm spindle, so assuming from your comment above that your running SRAM cranks that use a DUB BB, you'll need a new BB. Depending on what standard your frame is using, then you could be looking at around £40 ish for a new one?
So maybe nearly £200 to change your crankset if you went for the Race Face one or equivalent that would allow small chainrings and then you would need to be swapping out chainrings dependent on what riding you were planning on. None of this is going to be cheap though.
At the end of the day, it's run a larger cassette or smaller chainring. Larger cassettes are expensive and would require a new derailleur that would have the capacity for the larger cogs. New chainset that would allow for smaller chainrings would definitely be easier and cheaper, but still not cheap.
Even the conversion I've undertaken has involved a new GX Eagle Derailleur, GX Eagle chain and Cassette and the Ratio Conversion kit. I collected the components over a period of 8 months or so and waited for items to be on sale, even then this conversion cost me over €300.
oxoman
I was led to believe that 10 to 44 is the biggest i can go with current rear derailleur. Plus supposably you can't mix eagle with the rival xplr axis mechs.
chriswoody
chriswoody
Northern Germany
You are correct, Rival XPLR has a max capacity of 44t so that's why I suggested in my post above, that swapping your derailleur for a GX Eagle one will allow you to then fit a wider range Eagle cassette. A wide range cassette will fit straight onto your existing hub with no modification as well. With SRAM the same AXS wireless protocol is used across their entire AXS range, so yes a GX Eagle Derailleur will work with Rival shifters.
https://support.sram.com/hc/en-us/a...rs-compatible-with-Eagle-AXS-rear-derailleurs
As I wrote above, you have two options when it comes to lowering the gearing on your existing groupset.
Option 1:
Change the Rival AXS Derailleur for a GX Eagle AXS Derailleur. Then fit either a 10-50 or 10-52 Eagle cassette.
Option 2:
Change the crankset for one that will allow you to use a smaller chainring than 38t. The example I gave you was to use Race Face Aeffect crankset. Which will allow you to use a range of chainrings from 28t to 36t. For this option you would need to also change the bottom bracket, but the Race Face cranks will work perfectly with the rest of the drivetrain.
As for the low cost though, neither of these options are cheap, but unfortunately that's the price you pay for wireless groupsets.
oxoman
Thanks for clearing my misunderstanding up. I'll have to see how i cope with a couple of rides I've got coming up, 1 is without baggage but 200k in a day whilst the other is about 75k with full bikepacking gear. Both routes involve a fair bit of climbing and mainly offroad. In the meantime I will look into the cheapest / easiest option.
chriswoody
chriswoody
Northern Germany
Bloomin hell SRAM! Just when you think you fully understand something they go and change the standards on you!
So it's not the mechs that can't mix, it turns out it's the cassettes. So, on my bike with SRAM Rival mechanical, I've always had the off-road XD driver hub and I stupidly made the assumption that your bike would be the same. Nope, it seems that the new Rival XPLR series now uses the road hub XDR driver. So whilst you could pair a GX Eagle derailleur with your shifters, you can't use an Eagle cassette on your hub. So rendering the whole exercise pointless.
So to recap, option 1 above of using Eagle Derailleur and cassette won't work, leaving you with only the option of changing the chainset.
https://support.sram.com/hc/en-us/a...rence-between-SRAM-Eagle-and-XPLR-drivetrains
apologies for any confusion caused, I completely missed the fact that they've changed the hub standard.
oxoman
No worries. I'm wondering about possibly changing the wheels and that way possibly going to eagle if the rear mech will play ball.
chriswoody
chriswoody
Northern Germany
Changing the wheels would definitely mean you could go for a hub with an XD driver and then you will be able to use a wide range Eagle cassette.
Alternatively I discovered you can fit an Eagle Cassette on to your existing XDR driver hub with the addition of a 1.85mm spacer behind the cassette.
So to recap on your existing set up, you could:
Fit a 1.85mm spacer and Eagle 10-50t cassette.
Fit an Eagle AXS derailleur which will play nicely with you Rival Shifters.
Fit an Eagle chain.
This is the simplest route, but certainly not cheap for a proper wide range gear train with a lovely low set of gears for bikepacking.
I found this compatibility chart from SRAM that helps to decode all of this:
https://www.sram.com/globalassets/d...d/axs-components-compatibility-map.pdf#page=2
chriswoody
chriswoody
Northern Germany
So I've now covered over 2400 km on this drivetrain and thought I'd post again on my thoughts and experiences.
Drivetrain Range.
The whole point of this exercise was to create a more useable drivetrain than what current 1x or 2x drop bar drivetrains could offer. I settled on 500% range and with the 34t chainring, have a range of useable gears from 18 to 95 inches. So on my local trails it was nice to have the extra low gear for the ever present sand, especially with the dry summer we had. It wasn't essential though and I could have got by without it. Where the range really came into its own was when I was bikepacking. This summer's big trip was a 8 day crossing of the Alps, the climb profile below shows a typical morning climb. Bear in mind as well, that this was offroad on loose chunky gravel, so little grip. I couldn't have been happier with this new drivetrain, it gave me all the gears I needed and overall I'm really happy, this is what a proper gravel bike drivetrain should be. Whilst the top end is lower than that on road bikes, for me, on the terrain I ride, I never really had a problem with spinning out.
The Technical Side of things.
So how has it been from a technical standpoint? From the beginning I was really impressed with Ratio Technology's products, incredibly well engineered, easy instructions and an end result that was indistinguishable from something SRAM themselves would produce. I've only had one problem with it and that has been nothing to do with the conversion itself. The B Screw on the derailleur kept loosening off which would throw the indexing out. I had no end of issues trying to get it to stay in place, not helped with out of date Loctite and not being able to get fresh stuff around here. I seem to have finally got it to stay in place and when it is correct, the transmission shifts flawlessly and feels just like a brand new SRAM transmission.
So overall I'm really pleased with the conversion and so glad I did it. It means I no longer have to faff around changing the chainring size every time I want to go bikepacking or riding in hilly terrain. For anyone using SRAM 1x transmissions on their gravel bikes I highly recommend it.
