CTC or British Cycling
My Mum was worried about me (bless her) when she found out I had no form insurance (legal or third party) with the mileage I do (a lot in her opinion) and I had toyed with the idea of joining one of the above organisations. My mum has offered to pay every year as an ongoing Christmas pressie:smile: Is there any reason I should badger her into the £40 for CTC over £28 for British cycling (she is a pensioner after all and normally spends about £30 quid on me)
Are both memberships as good .... its mainly the insurance and legal cover aspects I want......
phil_hg_uk
I am not a member, I am a free man !!!!!!
Use this here -> CLICK ME and also check quidco as they usually have an offer on as well and then use them both.
Doesn't matter if in London - however can only use the link as a new member, ditto quidco. Can get a few quid off BC membership though if set up a direct debit
simon the viking
You dont need to be in london just use the code TFL13 when you join, I used last years code and I am in Yorkshire and I ended up paying £2.50 for my BC membership after using that and Quidco.
Thanks couldn't see anything on quidco at moment but will look again nearer Christmas
simon the viking
Are you in a club? They'll probably have affiliate status with either BC and/or CTC.
I know mine requires you to have insurance and affiliate membership's about £16.
No not in a club, I can see why they would want it though. I just want it for a bit of piece of mind
simon the viking
Thanks folks I think I will try B.C as that's nearest to my mums budget... so will get her renew it every year as she's always badgering me for what I want for Christmas
Stonechat
I have dithered
I would like to do rides with CTC but they are not near enough for me (maybe when I am fitter) local cycling club is near but distances too long.
So I have no reason to join one or the other CTC or BC
Having retired early I cannot get CTC at pensioner rate though I can get it at unwaged rate (otherwise it's £41). If I could get a really good deal with codes to reduce the cost that might make me take the plunge, The TFL code brings it down tftom £28 to £23.33
cyberknight
They offer essentially the same benefits except the CTC gives you a magazine and are a bit more active with campaigning.
I have the BC ride membership and i am happy enough with it .
You can get the cover even cheaper as a ctc affiliate member , is it @dellzeqq who does this very cheap ?
Banjo
Fuelled with Jelly Babies
South Wales
You may not need to be a London Cyclist to use the TFL code but personally I wouldnt unless you genuinely are.
British Cyclings underwriters may take a stricter interpretation of the rules should you ever have a third party claim against you.
Stonechat
In my case I do stray over the greater London boundary from time to time
Tyke
Agreed the last thing you want is them canceling the insurance just when you need it the most.
