We all have our opinions, like you say.Thought I'd chip in to this as I have a vested interest. What with me being the editor of Cycling Plus and all. I've just looked back over the last issue and found the offending caption and hands up, I missed it. That said, I'm no engineer so I'm going to consult one to check if this is, indeed, BS. (Yes, it's a bit late now but...)
But a couple of points: Mickle "Cycling Pus is and always has been full of shoot, and don't get me started on that Paul Vincent character." You're perfectly entitled to your opinion about the magazine, and I'm perfectly entitled to disagree but for future accuracy Paul left Cycling Plus some time ago.
And Smokin Joe. Likewise we're all entitled to an opinion but I definitely don't agree with: "As 90% of modern cycling journalists are clueless self-gratification artists who swallow any old shoot fed to them by marketing men they write exactly what the manufacturers intend them to write, ie crap that is designed to make the readers think they must have a different bike for evey day of the week" They're not and they don't.
Rob
Rob
Well, I'm an accountant but, IIRC, all other things being equal and simplifying hugely, a solid bar will bend, a hollow tube will crumple.... but do we really need an engineer to tell us if a top tube bends like a leaf spring or not?
It isn't actually a triangle at all, it has four tubes.The main frame of a bicycle is admittedly slightly more complicated as it is not a perfect triangle.
Now a 'bent' tube can be equally capable of resisting the bending moments but will be far less capable of resisting the compression loads. As it's already 'out of column' a much smaller compressive load will get it to continue to bend compared to a straight tube. This might be seen as a bad thing, but as long as the 'springiness' of the tube is sufficient to return it to its original shape, then you have a mechanism that can absorb, rather than simply resist the loads.
This is why things that we want to bend, like springs, are made out of solid bars whereas things that we want to be stiff (like frames) are made out of tubes.
Although anyone who has looked along the wing of an aeroplane in turbulence will know that there is further simplification behind the line that aluminium doesn't flex and it'll break if it does so.
I guess we do need an engineer after all.![]()
I had always thought that the intention behind bending the top tube was to make the connections at either end of the tube closer to 90 degrees, which would reduce the propensity of the tubes to tear apart at the top when the bike is compressed front to back - the crudest example I can think of would be a rear end impact. The Spesh top tube to head tube connection is broad, and, I would imagine, very stiff and strong. I don't particularly care to think about this, but it might be better able to resist the tension force that gave me a small crack in the lug of my conventionally framed bike.Well here goes!
We all know that a triangle is very rigid in the plane of its component parts. What ever loads are applied to the corners in the direction of that plane are resisted by each of the three constituent parts being either under tension or compression along their axis. The only way a triangle can 'fail' is if one of the sides that is under compression comes out of column (in other words bends or buckles) or a side under tension fails (breaks).
The main frame of a bicycle is admittedly slightly more complicated as it is not a perfect triangle. The top tube is subject to a combination of compression and a bending moment imposed by the leverage imposed by the fork. These forces are resisted by the 'stiffness' of the top tube and, especially with compressive loads, by it remaining as a straight column. Any deformation below its elastic limit will see the tube's 'springiness' return it to its original shape when the load is removed.
A common spring of this shape is indeed the leaf spring but the analogy is poor because the way a leaf spring is loaded is rarely by compression and a bending moment imposed along it's length.
The theoretical rationale is ok, whether it works in practice - I have no idea.
