buddha
I noticed a small bulge on my front tyre today (Vittoria Diamante Pro - about 4 months old). It was only minor and barely noticeable if I hadn't been checking the tyres over. So I checked the tyre on the outside for damage - but found nothing. Not even a scratch.
However, on the inside there is a small (3-4mm), clean cut, going through the innermost threads. The inner tube was fine with no debris that could have caused the cut. I fixed a patch over the cut and the bulge has gone.
So far I haven't had a single problem with these tyres and can't fathom how they managed to cut from the inside. As I've said, no punctures, pinch flats etc.
Could this be a manufacturing fault? Anyone with experience of this?
(they go on/off quite easily TBH)
), not even a scratch. And there is hardly any sign of wear. Even though I use them only in the, not so well maintained, lanes. I ride over two 'craters' every day, left from the remains of a couple of burnt out cars!, and they cope fine. Over a smashed bus shelter, after England's last match, no cuts ...
