Cycling from Gloucester to Bradley Stoke
Archeress
Bristol
Hi, I'm thinking of taking the train to Gloucester and then cycling back along NCN41. I was wondering what the surface is like on the path from Gloucester to Frampton? For cycling that sort of distance I would want to use my road bike. It has Gatorskin road tyres fitted, can anyone advise whether it is doable on a road bike?
Ta, hugs
Archeress x
Rasmus
Without a clever title
Bristol
I've wondered the same thing myself during speculative route considerations.
Checking again, I've just found that google streetview has found a way onto the path!
Doesn't look road bike friendly, at least not this bit.
Edit: Looks a little better south of Frampton, which is the critical bit to avoid the A38.
Rasmus
Bristol
[QUOTE 3807905, member: 45"]I've just ridden the A38.[/QUOTE]
Doable, yes, but not particularly pleasant.
Archeress
Archeress
Bristol
Yes, was hoping to take NCN41 down to Frampton, then Slimbridge, Berkley, Littleton on Severn, Tockington and Almondsbury.
Hugs
Archeress x
twentysix by twentyfive
Clinging on tightly
Over the Hill
I've ridden the bit between Frampton and Slimbridge. Doable on a road bike but often times there are walkers, kiddies and fishermen to take account of. Mostly chunky gravel. The A38 alternative isn't very pleasant but I've done that too. The rest of the Sustrans route is lovely
the_mikey
It's hard to avoid the A38, you can take the lanes via Saul and Frampton on Severn but you will be ejected onto the A38 again until Slimbridge where you can take the lanes again via Berkeley, Ham, Rockhampton, Thornbury, Tockington then Easter Compton.
Profpointy
It's OK once you're past Gloucester to be honest. Quite wide, and actually fairly quiet as most folk are on the parallel M5
The tricky bit is if you try to start from Cheltenham, where you can't avoid the nasty dual carriageway bits
EDIT - above referring to the A38
