Cyclocross tyres
I'm considering trying a summer cyclocross race, but I only have my winter road bike to use. What are the narrowest cyclocross tyres available, since I think I can only fit 25's at most. :rolleyes:
PpPete
Chandler's Ford
Schwalbe CX Pro are nominally 30mm. I don't know of anything narrower than that. Most are 32s or 35s I believe.
I've got a pair of Schwalbe's you can borrow to try, if you are anywhere close, or don't mind paying postage ?
Jezston
London
You sure you can only take 25s? Those are some pretty seriously narrow wheels if so. Or / and are clearlances that tight?
You really aren't going to be able to do cyclocross if you can't fit at least 32s, IMHO.
2old2care
2old2care
Well the bikes a winter road frame, and the maker quotes that it will only take 25's max. But I've just had a measure and I think the rear will just take a 30, and maybe the fork aswell, but this will be close, carbon fork with mudguard clearance. If I knew how I'd post some photo's :rolleyes: :biggrin:
Thanks for the offer Pete, but I'm still undecided at the mo.
Jetzon why do think 32's are a min recomendation as it's a summer race and hopefully the ground will be a bit harder.
P.H
Summer Cyclocross??? Whatever next, winter cricket?? Cyclosross has always been a winter sport. I suspect your race isn't anything official? UCI rules are that tyres should be a maximum of 33mm, 30s are the most common. It used to be usual to use something narrower like 28s. A bigger problem than tyre size will be brake clearance if it's wet (Yes that can happen even in summer!) It's not going to take much mud to clog a std reach caliper and they're not as easy to clear as cantis. The other problem is pinch flats, a lot of cyclocross bikes still use tubs for this reason, they can drop the pressure right down without worrying. A rough course on 25mm tyres at a pressure high enough to avoid flats might be more than a tad uncomfortable. But if it's meant to be a bit of fun, take what you've got and have fun :biggrin:
If you want to squeeze 28mm in, try it with the brake quick release open, it'll be a pain if you do get a puncture, but then your race will be over anyway.
2old2care
2old2care
I've never done any type of racing ever! and I thought that racing off road ( mountain biking doesn't interest me ) without the team tactics would be more to my liking, less formal, it's run under TLI rules I think! But as a first attempt I didn't want to spend too much on something I might only do once or twice and then never again. UCI I don't think they will have even heard of TLI, besides it's only a local league run for the convenience of local racers and designed to get more people into the sport :biggrin: :biggrin: :biggrin:
Although the point about the high pressure of the 25 clincher tyres is a good one, as I think it would be uncomfortable, maybe I'll try to come up with another way around the tyre issue.
