Dahon servicing
Stu99
Can anyone recommend a competent Dahon servicing centre in the South East (Sussex) or possibly London?
StuAff
Silencing his legs regularly
Portsmouth
Why do you need a 'specialist'? Any competent bike shop will do a decent job. My folders (I'm on my third Dahon) have always been serviced by my usual LBS. If they don't stock model-specific parts like hinges etc, they can always order them in...
S
Stu99
I suspect the LBS overtightened the clamp on the main hinge and so I'd like a second opinion as to whether this has compromised the frame which creaks terribly unless tension is released from the clamp to the point which I consider unsafe (at least to my untrained eye).
StuAff
Portsmouth
Certainly doesn't sound good. Creaking usually means problems with either hinge, or worse frame (hinges went on both my Jetstream XP and my Cadenza...!). Whereabouts are you? TMN of this parish has said good things about Future Cycles in Lewes, who I believe are Dahon dealers. Plenty of decent LBSs all over Sussex though...(certainly not including the one you went to!).
RecordAceFromNew
Swinging Member
West London
I have no idea which model and what type of hinge you have, but I do know that if the stainless steel strut within the hinge type below is bent, terrible creaking results.
I do agree an opinion by a Dahon specialist is worthwhile in your case, but specialist identification depends on where you are.
This has some basic instructions. If you are quite capable with maintenance and repairs for the hinge type below I might have a guide that could help you taking it apart and repair / replace.
S
Stu99
Thanks for advice - will see what I can arrange and feedback if/when problem resolved.
London
Hope the OP gets it sorted.
Intrigued as to why you went for another Dahon Stuaff after 2 hinge failures.
StuAff
Portsmouth
Both were on second hand bikes, I had absolutely no idea how much care and attention (or not) was paid to looking after the hinges. Almost certainly wear and tear and/or lack of maintenance rather than quality control, though. Chutney, on the other hand, had a careful owner I know and a recently replaced (and newer model) frame. Haven't actually folded it yet but not anticipating problems when I do.
London
Yes, I know of your careful owner (he is) - I think I might be the person wh encouraged him to get in touch with Dahon for a frame replacement. Interesting that you've not folded it yet - can I ask why not, at the risk of diverting the thread.
StuAff
Portsmouth
Not had any need to fold it, simple as that.
London
Can't help thinking that this rather removes much of the point of the bike and its frustrations (though I accept its plus points/sheer fun when it works) to be honest - please note, Stuaff, I'm not criticising you. Mine is only rarely folded as well.
PS _ was on a ride with a guy with a new Dahon yesterday - he'd had problems with rear wheel spoke breakage and a bottom bracket which fell out when he was riding it! - I'm not ultra mechanical so have real trouble tryig to figure how the last fault could have happened.
Any news from Stu99?
Brommyboy
Rugby
The greatest strain on the hinge is when the bike is in use. As far as faults of assembly go, few cycle emporia actually check the whole over properly before sale. Uneven tension in the spokes will lead to failure, and a bottom bracket is locked in by the LH fitting, which, if not properly tightened, will unscrew itself. It certainly pays to learn more about checking and servicing your own bike, most of which is not too difficult. Specialist tools as required are still much less costly than failure.
London
My Dahon definitely wasn't checked over properly by the LBS who shall remain nameless. The Dahon owner I encountered on the ride got his from Chain Reaction, normally an excellent company. Thanks for the info on the bottom bracket - I've changed a few but never really thought about this.
S
Stu99
After a bit of internet research, I solved the squeaking/creaking problem entirely with a couple of applications of a dry lubricant spray at the main folding joint.
