henshaw11
- Walton-On-Thames
As the owner of some old (halogen) Lumicycles (I think ~12w on my helmet), and an Ixon IQ:
a) unless you've got a wide angle bulb/led unit - and narrows are generally most useful off-road anyway (or at least, wide on bars, narrow on helmet) - you can generally point them at the road where they're both most useful, and not going to dazzle anyone - and that applies to both 'bar and helmet mounting IMO. Or at least, in ~10yrs of using them, I don't recalled being flashed, other than *possibly* once or twice, and given I tend to use the hlemt mount, I may not have been pointing directly atthe road. I guess a wide-angle unit could well be more of a problem, but I think most leds and halogens tend to be narrower.
b) dip setting - unlike a car headlamp which has a cutoff on dip, all you can sensibly do is reduce the power - and it could still dazzle a bit if pointing to the wrong direction. You still need to be able to see the road in urbans areas anyway, so you'd wind up at lower power all the time, which wouldn't help that much with seeing the road.
c) the Ixon IQ has a shaped reflector, but on low power (on a lowish bent at least) can actually be a little disorientating because the curb edge doesn't get much illumination, and wouldn't be much use off-road because the cut-offs so extreme.
d) until more recently, the more powerful end of the lighting market was really aimed at off-road use (where you don't want a cut-off) and relatively expensive until the cheaper dealextreme/magicshine things came out.
It took years before the uk lighting regs accepting anything other than steady incandescent illumination, so I wouldn't hold your breath for regulation ! - tho' you might get stopped by the Police if they were ill-aimed.
BTW - there are some German standards that the Ixon is made to - which I *think* requires a minimum, steady, illumination level, whereas in the UK there's no minimum requirement AFAIA, never mind anything else.
