ChrisEyles
- Devon
I've been trying to work on my cycling technique over the last year, and have made good progress with cadence, pedalling in smooth circles, and keeping a nice relaxed position... but I still feel decidedly unconfident on fast descents and corners.
My main issue is drifting wide due to not being able to corner as sharply as I want to. This is especially a problem on right hand bends, where running wide would mean hitting the hedge/ditch/wall on the left hand side. I've had a few scary moments where I've not been at all sure I'll make it around without a trip over the handle bars, and one incident where exactly this happened, at reasonable speed (fortunately bike and head were OK).
Here's what I'm doing (or trying to do) now:
- Rely mostly on the front brake for stopping power and use the back to augment this where necessary
- Brake from the hoods and keep my hands there throughout (I get the serious fear going into the drops on uncomfortably fast corners! But mostly feel I get adequate braking power from the hoods)
- Brake hard-ish on the (straight) approach into a turn, and allow the bike to accelerate on the way out (rather than applying a softer continuous braking force during the descent)
- Keep weight on the outside pedal, and lean the inside knee a little into the turn
- Lean the inside shoulder a little forwards and into the turn, keeping the tilt of the body equal to the tilt of the bike
- Keep a relaxed grip on the bars with soft arms, and weight shifted back on the saddle (I have real problems eliminating excessive tension in my legs though)
- On unfamiliar hills, proceed at granny-pace so I'm not caught out by any nasty surprises!
- When riding with friends, ask them to go in front and allow a good distance between us
Does this sound sensible? Maybe I just need a little more confidence to lean further into the corner to make the turn a little tighter... I will admit to a bit of a mental/physical block about doing this, with my hind-brain yelling at me that I'll slide the back wheel out and fall off if I do!
If anyone's got any good advice/tips to share, or is suffering from similar difficulties, I'd love to hear them!
