PpPete
- Chandler's Ford
One of the boys has a disc braked MTB (cable operated). Discs are something about which I nothing.
Just in the last few days rear wheel has started rubbing in only one place around the rotation - not much, just enough to stop the wheel turning freely when spun off the ground, but not enough to slow the little tyke down.
All the bolts are tight, so I'm thinking he's bent the disc very slightly (he's not exactly careful) Difficult to see any "wobble" but can't think of any other cause?
I'm thinking next step must be to remove the disk and check on a flat surface, then replace if I can't tweak it back to flat with an adjustable spanner?
Any other suggestions?
