Does acid wear out?
swee'pea99
Apparently if I get a new battery off the web, it'll arrive without sulphuric acid - which seems wise on the whole - but they say I can get it at any friendly local supplier. Since I don't have one, I wondered if I couldn't just transfer the acid from my old battery. Would that work?
zimzum42
Damn. I found a load of old LSD tabs and thought this thread would answer the question that has been bugging me for a while.
Seriously, I have a load, more than ten years old. Will it still work?
Norm
The acid gets all sorts of contaminants, which is one of the things which will be stopping your current battery from holding a charge. Putting that into a new battery would be pretty dangerous but I would expect it would also reduce its life considerably.
Bman
Herts.
I was under the impression that you only had to fill the new battery with distilled water and charge it, the charging process would then turn the water into acid. But it seems that may not be the case with newer batteries?
swee'pea99
swee'pea99
That's brilliant - thanks Debian (and others). Just goes to show...I almost didn't post, thinking 'don't be daft, how can acid 'go off'?' But it does. You learn something new every day!
