Does anyone know, 7's and 9's
Psycolist
NINJA BYKALIST
North Essex
Is it possible to use a set of 7 speed Shimano STI shifters on a 9 speed cassette, I of course realise that I would have 2 redundant rings on the cassette, or put another way, is the distance between the rings on a 7 speed cassette the same as on a 9 speed ? Can anyone help please?
cyberknight
Not as far as i know.
The sprockets have a different width on the cassette , as the number of gears have increased the width between them and the matching chain has got smaller so it would not index properly across the whole cassette rather than just missing 2 gears at one end.
JonoB
West Lothian
I think chains are the same for 5-8 gears. 9 went narrower so the answer is probably no as the indexing will be out and the constant clicking would drive you mad!
GlenBen
There is an article on sheldons site, ill try and find the link, about this. Im sure it says its possible, bit it wont perform well and will need modifying a bit. Any reason you dont just want a 7 though?
GlenBen
If your 126 mm frame is aluminum, carbon fiber or held together by glue, you shouldn't try to spread it. That still doesn't mean that you're stuck with 7 speeds!
Any 7-speed Shimano Hyperglide Freehub will actually work with 8 or 9 sprockets, without any modification! What you need to do is to use 8 of the sprockets from a 9-speed cassette, with the 9-speed spacers -- or 9 of the sprockets from a 10-speed cassette. This trick also is useful when cassette body transplantation isn't possible -- on an off-brand hub or a Sachs 3 x 7 hybrid-bearing hub.
To make this work, you'll also need to use a 9- or 10-speed chain and shifters. Your old 7-speed derailer (except 1996 or earlier Dura-Ace) should work OK if it isn't too badly worn. Most, but not all, 9- and 10-speed shifters will work.
The limit stops on the derailer will cause the useless position on the shifter to be locked out, so this will work as a perfectly normal 8- or 9-speed rig.
Reader Justin Mohar writes:
I ran a "9 cogs of a 10 speed" set up for about a year on my road bike (having been originally inspired to give it a shot after reading Sheldon's "8 of 9" article) while waiting to build a new bike with a true 10 speed set up. I used an Ultegra 10 speed cassette (with the 4th cog and one spacer removed) on a 7-speed 105 hub. I also, of course, used 10 speed shifters (105) and chain (Dura Ace). My cranks and derailers were all 105 "7-speed," from the same group as the hub. This setup worked surprisingly well; the only issue was that shifting across the spot where the missing cog should have been was rather slow in both directions. I assume this was because the shift assist ramps on the now-next-to-each-other 3rd and 5th cogs did not line up properly, but I never really confirmed this in any way. Bottom line: it can be done. Feel free to post this info with your next update.
Justin is right about the reason for slow shifting. This issue is more acute with the narrower 10-speed inter-sprocket spacing. If instead, you remove the smallest or largest sprocket, all of the ramps will line up. Most 10-speed cassettes, and the fancier 9-speed cassettes, use a spider assembly for the larger sprockets, and so you would only be able to remove the smallest sprocket. You would need then to replace the second sprocket with one that has a built-in flange.
You could even have all 8 of 8 sprockets on a 7-speed body if you go to the trouble of dishing the inner sprocket -- or even a 9 of 9 or 10 of 10 if you bolt the innermost sprocket to the next smaller one. A dished sprocket was at one time a commercial product available from Tom Ritchie, but this now is a do-it-yourself project. More details are here.
RecordAceFromNew
Swinging Member
West London
To make this work, you'll also need to use a 9- or 10-speed chain and shifters........
Therefore if you have tried it you will find the answer is no because your indexing will be pants. However, at a push you can mix and match sprockets of Shimano HG 7 and 8 (and, less ideally, 9) speed cassettes if both are not "spidered" by keeping the 7 speed spacers (see indication of sprocket and spacer thickness here) which I have found to work and index ok, and which is improved by putting the shifter on to the middle sprocket and set rear derailleur cable tension by centering the mech on that sprocket.
TheDoctor
The TerrorVortex
Easiest thing to do is use a 7 speed cassette!
The spacing between sprockets varies - that's how a 8, 9 or 10 speed cassette fits onto the same freehub.
If you're fitting a 7 speed cassette onto a 8-9-10 speed hub, you'll need a 3mm spacer.
But using a 7 speed STI on a 9 speed cassette won't work.
Psycolist
Psycolist
NINJA BYKALIST
North Essex
Just economics, It would only be a temp situation, Rather than wait until I get a 7, could I use a 9 i've already got............Seems to be a resounding no though.
Psycolist
Psycolist
NINJA BYKALIST
North Essex
Thans every body for all you input, it seems the consesus is a resounding NO but it will save me trying it and failing, or worse still, damaging something Ta everyone
