Broken part of Shimano RX100 rear derailleur - does it matter?
Aston
I've managed to break a plastic part on my rear RX100 derailleur, whilst stripping the bike to clean, does it matter?
It appears to be a cover and not structural.
Any advice. Thanks
Should be fine - I'd maybe glue it so it doesn't get worse.
Ajax Bay
East Devon
Answering OP: I haven't got that actual RD in my 'box' but the plastic part on others of that vintage/hierarchy looks to be a 'seal' to keep cr@p out of the cage tension spring. RD will function fine but you may want to service it more frequently (with the hassle of taking that bit apart). This video gives a clear sight of your broken plastic bit's function.
View: https://youtu.be/aH9fd2fYGx4?si=niWo36hzI2eg-nsX
Get a camera that can focus
Suggest you are being harsh with no OP fault, 'Ming'. Appreciate you are looking through specs, but look again with care: the cracked plastic bit is in sharp focus - in my unaided view/sight.
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Answering OP: I haven't got that actual RD in my 'box' but the plastic part on others of that vintage/hierarchy looks to be a 'seal' to keep cr@p out of the main spring. RD will function fine but you may want to service it more frequently (with the hassle of taking that bit apart). This video gives a clear sight of your broken plastic bit's function.
That’s not sharp focus.
fritz katzenjammer
Der Ubergrosserbudgie
Given that a good clean used one is $15 at the local bike co-op and a really nice one is under 50 on eBay I wouldn’t bother with it and would replace it.
if it does become a problem it’ll be when you are far from home with it so why take the chance.
Bristolian
Bristol, UK
@Aston : It looks to be a cover or maybe some kind of seal. Is it important? Who knows, but I doubt Shimano would have wasted their time designing and having it manufactured if it doesn't do something; even if that's just to keep dirt and muck out of whatever is behind it.
