Does anyone know about suspension bridges???
Spinney
Bimbleur extraordinaire
Back up north
Cycling over the Severn Bridge a couple of days ago (lovely bridge!).
I've seen these things on the suspension cables before - anyone know what they are for?
They only appear on the cables once the cables are longer than the lamp posts, and are in pairs (i.e. two bits of wire mounted near each other, both with those 'blobs' on the ends).
When the suspension cables get even longer (i.e. 2 x lamp post height), another single 'thing' appears higher up.
My only guess is something to help stop the cables vibrating in the wind? But why pairs, and why the weird shaped blobs on the ends?
HorTs
Portsmouth
Spinney
Spinney
Back up north
Thanks @HorTs !
I thought of googling, but it's a bit difficult when you don't know what the things are called!
One of the replies to the New Scientist question stated that the pairs on the Severn Bridge cables were set at 90 degrees to each other to damp vibrations from any wind direction - they did look as if they were at right angles.
But on the longer cables, where there was another 'cable clinger' higher up, there was only one, not two of them. Maybe those are just adjusted for the prevailing winds?
Archie_tect
De Skieven Architek... aka Penfold + Horace
Northumberland
Building foundations in high risk earthquake zones also have mass dampers for the same reason... modern skyscrapers also have them on the roof to counteract wind oscillation.
swansonj
We have them in our business too. We don't do such specific tuning as the Severn Bridge ones, we just slap one or more standard models at the end of the span, but the distance out from the clamp is related to the likely position of nodes and antinodes. Here is a younger me and and even younger and considerably prettier colleague (who quite rightly went on to be my boss for a while) almost sitting on some:
Smurfy
Naturist Smurf
OK, now the OP has been answered, could I take the liberty of asking Swanson to explain how those multi part insulators work that he's sitting on?
slowmotion
Quite dreadful
lost somewhere
Don't think so - they added weights to damp the vibrations, but it's not a suspension bridge, so the vibration was different. IIRC.
Two types of damper were used according to Wiki...
After extensive analysis by the engineers,[9] the problem was fixed by the retrofitting of 37 fluid-viscous dampers (energy dissipating) to control horizontal movement and 52 tuned mass dampers (inertial) to control vertical movement. This took from May 2001 to January 2002 and cost £5M. After a period of testing, the bridge was successfully re-opened on 22 February 2002. The bridge has not been subject to significant vibration since. In spite of the successful fix of the problem, the affectionate "wobbly bridge" epithet remains in common usage among Londoners.[10][11]
vernon
Harder than Ronnie Pickering
Meanwood, Leeds
Cuchilo
Prize winning member X2
London
The Tacoma bridge collapse was a totally different form of failure. The major factor in the collapse of the bridge was the large amplitude low frequency oscillations caused the slab sided decks catching the wind and not the relatively high frequency low amplitude oscillations of the cables.
I concur .
