Don't shoot! 11-28 vs 11-32
mwktar
Merthyr Tydil
Hey guys, live in a hilly area and just made the move to a compact 11 from a triple 9. I can definitely notice the gaps between gears.
I live in a particularly hilly area in South Wales and an considering swapping out the 28 for a 32.
Anyone used both of these setups? I'm wondering how noticeable the jumps between gears are between these 2 (not the triple, as either way i have to get used to that)
I have. SRAM 50/34 front 11-32 rear set ups on all my geared bikes, wouldn't have anything else, do t notice gaps but I've ridden little else for some time (another bike was 12-30) :smile: and it's not hilly around here. Today I've ridden 43 miles, 350ft elevation...but I was on the single speed with a strapped up knee so hills were to be avoided :biggrin:
deptfordmarmoset
Full time tea drinker
Armonmy Way
I've got a 32-tooth cassette on both a triple and a compact so I'm pretty used to the large step between gears. Perhaps you just learn to be a little more flexible with cadence because I never get the feeling that I'm missing a sprocket in between.
jowwy
Can't spell, Can't Punctuate....Sue Me
Were in south wales and i feel your pain being a south walien too
And i would never drop my triple for any compact set-up
Banjo
Fuelled with Jelly Babies
South Wales
I have 34 /30 And think when the cassette /chain needs replacing I may look into changing to 34 / 32.
On fresh legs I can climb anything but towards the end of a long ride could do with a couple more teeth on the cassette.
I don't think the slightly bigger steps between gears will be an issue.
DaveReading
Don't suffer fools gladly (must try harder!)
Reading, obvs
I have an 11-32 cassette on my tourer and a triple (48/36/26) chainwheel.
One tip I use if I want to minimise the jump when changing up or down on the front is to change simultaneously in the opposite direction on the rear.
mwktar
mwktar
Merthyr Tydil
That's the answer i'm after really, thatr im not gonna be wishing for that "in between" gear
Merthyr Tydfil I am butty :smile: Yeah i avoided a compact for years unitl i saw the ratio on an 11 speed was almost the same as my 9 speed, plus wanted to upgrade to a carbon and was fairly limited in choice - where are you in S.Wales?
Dogtrousers
Kilometre nibbler
I ride 50/34 and 11-32, (10 speed on one bike, 8 speed on t'other) and the gaps between the sprockets have never bothered me. But I'm not a sensitive thoroughbred.
The double change needed when swapping chainwheels, I do notice but it's no big deal.
Your best option is ride more get fitter.
Leave out the hills till you can do it.
I used to ride a triple with a 28t cassette, when I bought a new bike there was no option for a triple, so I went to a commpact set up and a 12-30 cassette. It took me a while to get used to the gears, but you soon find the right combination for most situations. As I am a little fitter now, I am using a compact with 11-28 in a fairly hilly area.
bikeman66
Isle of Wight
I guess there wil be a bit of compromise somewhere. I really noticed the gaps in the ratios (especially between the three lowest gears) when I swapped an 11-25 cassette for and 11-28 when I rode Mont Ventoux earlier this year. It did feel a bit odd at first, but then again, I doubt I would have made it to the top if I didn't have that 28 available.
I guess you have a similar situation. If a 30 or 32 allows you to comfortably ride the hills around your location then perhaps the gaps in the ratios are worth putting up with. You'll almost certainly need a new (longer) chain and make sure you check that the rear mech has the capacity to deal with what you are planning.
Dogtrousers
Kilometre nibbler
Vaguely relevant fact: Fabio Aru was rocking a 32T big sprocket on one of the stages of this year's Giro, as spotted by Juan Antonio Flecha after the stage. One in the eye for Henri Desgrange who said "I still feel that variable gears are only for people over forty-five. Isn't it better to triumph by the strength of your muscles than by the artifice of a derailleur? We are getting soft. . ."
