Dorking to Old Street routes
caesar
I'm hoping to move near Dorking this summer so my current 9ish mile commute will be at least tripling - think the fixie will be seeing a little less use (unless I can re-space an Alfine hub and squeeze it in there ;))
Any route suggestions? How do people find doing a 30 odd mile commute in winter, and how many times a week do you do it?
thomas
the tank engine
Woking/Norwich
I used to commute from Woking to Dorking. That was 15 miles and took about an hour on a good run. I did that in winter too (roads aren't lit for my rote back). It was okay, not the easiest thing - especially as I don't have super powerful bike lights. I don't know where you'll be commuting to, but I wouldn't be able to do 30 miles each way.
DJ
Formerly known as djtheglove
caesar said:
I'm hoping to move near Dorking this summer so my current 9ish mile commute will be at least tripling - think the fixie will be seeing a little less use (unless I can re-space an Alfine hub and squeeze it in there :biggrin:)
Well from Dorking you will either go up the A24 over the Downs or you could just nip up that lovley little bit of road called the Zigzag hill!!!!!!:smile:
:ohmy::biggrin:
thomas
the tank engine
Woking/Norwich
djtheglove said:
Well from Dorking you will either go up the A24 over the Downs or you could just nip up that lovley little bit of road called the Zigzag hill!!!!!!:tongue:
:biggrin::biggrin:
I took the A25...the A24 isn't too bad though, it has a reasonable cycle lane along the side of it - or you can use the duel carriageway.
