Banjo
Fuelled with Jelly Babies
- South Wales
Seen this term on some threads but not sure what it means.
TT/bar end shifters on bull horns are even easierjimboalee said:Now try doing these shifts with integrated brake/gear levers. Easy, isn't it?
summerdays said:I'm assuming it is when you depress the right hand shifter more and it shifts down 2 cogs at a time.
I've always thought that toosummerdays said:I assumed wrongly![]()
with some shifters you can change one gear by pushing halfway, two by pushing the whole way; I thought that was a double shift
Moodyman said:I've always thought that toowith some shifters you can change one gear by pushing halfway, two by pushing the whole way; I thought that was a double shift
Don't think that's a shifter trick though, it's more your gears are wrongly indexed.
)oliver said:well most the bikes i know of and have ridden, have this capability, and all have on the rear changer (most recent i can think of is the sora 9speed triple, which does on both shifters- or at least mine does)
HLaB said:I've always thought that toowith some shifters you can change one gear by pushing halfway, two by pushing the whole way; I thought that was a double shift
